AURIX™ MCU: Debugging ADC without hardware Trigger - KBA235479
Jul 04, 2022
10:33 PM
- Mark as Read
- Printer Friendly Page
Jul 04, 2022
10:33 PM
Community Translation: AURIX™MCU:ハードウェアトリガーを使用しないADCのデバッグ-KBA235479
Version: **
You can use conversions by software. For instance, to verify an ADC configuration without a proper hardware trigger. This helps to find the root source of ADC conversion issues while debugging. In case of AURIX™ TC2xx, for Scan and Background Scan, each request source has a LDEV (GxASMR.LDEV=1 and BRSMR.LDEV=1) bit that can load the ADC request source. For queues, there is a TREV field (GxQMRy.TREV=1) that is used to load this type of request source.
For more details, please see the “Versatile Analog-to-Digital Converter (VADC)” section of the User’s manual.
Note: This KBA applies to the following series of AURIX™ MCUs:
- · AURIX™ TC2xx series
Labels
- vadc
Rate this article:
