AURIX™ MCU: Debug code when a trap is asserted - KBA234672
Mar 14, 2022
05:21 AM
- Mark as Read
- Printer Friendly Page
Mar 14, 2022
05:21 AM
Community Translation: AURIX™ MCU: トラップがアサートされた時のデバッグコード – KBA234672
Version: **
For Tricore™/AURIX™ MCUs, the most common traps are Class 2 (instruction errors) and Class 4 (system bus and peripheral errors).
Do the following to debug your code:
- Put one or more breakpoints for the trap class in the Trap vector table (i.e., Class 2 and Class 4). The BTV (Base Trap Vector Table Pointer) register specifies the base address of the trap vector table.
- Reset and run your code. If a Class 2 or Class 4 trap is asserted, program execution stops at that breakpoint.
- Check register D[15] for the Trap Identification Number (TIN).
- Check register A[11] for the address of the instruction triggering the trap. For a synchronous trap, the return address A[11] is the instruction that caused the trap.
For more details, see the “Trap System” section in the Tricore™ Core architecture user manual (Volume 1).
Note:
This KBA applies to the following series of AURIX™ MCUs:
- AURIX™ TC2xx series
- AURIX™ TC3xx series
Labels
Rate this article:
