Jul 29, 2022
03:04 AM
- Mark as Read
- Email to a Friend
- Printer Friendly Page
AURIX™ MCU: Configuring additional flags in the toolchain configuration user interface in the AURIX™ Development Studio - KBA235940
Version: **
The tools available in the toolchain, enables the user to manually add flags by editing the Command line pattern under the Expert settings.
Open the Build settings of a project, right-click on a project, then select the Properties -> C/C++ Build -> Settings -> TASKING C/C++ Compiler.
Additional flags can be added manually after the placeholder ${FLAGS} in the Command line pattern text field, as shown in the figure below.
Note: This KBA applies to the following series of AURIX™ MCUs:
- AURIX™ TC2xx series
- AURIX™ TC3xx series
Labels
Rate this article:
