AURIX™ MCU: Calculate the timeout value of the CPU0 watchdog timer (WDT) - KBA235916
IFX_Publisher2
25 likes received 1000 replies posted First like given
Community Translation: AURIX™ MCU: CPU0ウォッチドッグ・タイマー(WDT)のタイムアウト値の算出 - KBA235916
Version: **
The timeout value of the CPU0 WDT can be calculated using the following formula:
timeout = ((2^16 - STARTVALUE) * Divider) / fSPB
Where:
  • fSPB is the frequency of the Serial Peripheral Bus
  • STARTVALUE represents the fixed value 0xFFFC for calculating the timeout period and the user-programmable reload value REL (bitfield of register WDT0CON0) for calculating the normal period.
  • Divider represents the user-programmable source clock division, which depending on the values of the IR0 and IR1 bitfields of the WDT0CON1 register, can get the following values:
  • Definition of bitfields
IR0
IR1
Divider value
0
0
16384
0
1
64
1
0
256
1
1
Reserved
The same formula applies to the other existing CPUs, replacing WDT0CON0 and WDT0CON1 registers, respectively, with WDTxCON0 and WDTxCON1, where x represents the number of the CPU.
 Note: This KBA applies to the following series of AURIX™ MCUs:
  • AURIX™ TC2xx series
  • AURIX™ TC3xx series
