AURIX™ MCU: Calculate the gain factors for EDSADC – KBA235517
IFX_Publisher1
250 sign-ins First comment on KBA 250 replies posted
Version: **
To achieve a correct calibration, the values for the Cascaded Integrator Comb (CIC) shift and gain factor must be calculated according to the intended full-scale value and the selected decimation factor.
The value for the CIC shift is determined by the following formula:Screenshot (47).pngWhere:
  • N is the selected decimation factor.
  • AFS is the intended calibrated full-scale value of the ADC (it refers to the analog full-scale 𝑉_𝐼𝑁=𝑉_𝐴𝑅𝐸𝐹).
  • FM is the modulator gain factor (when using the on-chip modulator FM = 0,6945).
Then, the gap that comes from the rounding in the above formula is closed by computing the corresponding gain correction factor:
That is finally multiplied by 4096 and truncated to be stored in the GAINFACTOR bitfield of GAINCORR register:
<GAINFACTOR> = truncate( gain factor * 4096 )
Calculation example:
Consider the following use case:
  • Use the on-chip modulator: this fixes the value of FM to FM = 0,6945.
  • Select a decimation factor N = 32.
  • Assume an intended full-scale value AFS = 30000.
The value for the CIC shift is then determined by the formula:Screenshot (44).png
And the gain correction factor:Screenshot (45).png
Which finally leads to the GAINFACTOR bitfield of GAINCORR register:Screenshot (46).png
For more information, see the AURIX™ TC3xx Expert Training.
Note: This KBA applies to the following series of AURIX™ MCUs:
  • AURIX™ TC3xx series
