AURIX™ MCU: Automotive Level (AL) in pads – KBA234969
IFX_Publisher2
1000 replies posted First like given 750 replies posted
Community Translation: AURIX™ MCU: パッドの車載レベル(AL) - KBA234969
Version: **
The pads on the AURIX™ MCU support both Automotive Level (AL) and Transistor-Transistor Logic (TTL) level. The AL is a standard CMOS level but with an extended low-level range.
For example,
The minimum input high voltage level value is 0.7 * supply voltage for AL, 2.0 V for TTL.
The maximum input low voltage level value is 0.44 * supply voltage for AL, 0.8 V for TTL.
This value depends on the product. For more information, see the "Electrical Specification" sections of the datasheet and the "General purpose I/O ports and peripheral I/O lines (Ports)" section of the User’s manual.
Note: This KBA applies to the following series of AURIX™ MCUs:
  • AURIX™ TC2xx series
  • AURIX™ TC3xx series
