I am using Infineon Designer how can we Add IPM IM535-U6D in System.
ispn:28861:1:0
l1:144:1:0
l2:231:1:0
There is dedicated IPM Simulation Tool where you can specify the input parameters and do steady state analysis for a particular IPM.
Please note that all simulations involve steady-state analysis. Losses calculated are only for the IPM, all other
components in the schematic are ideal and do not add losses to the system.
Rishabh S
The CIPOS™ IM535 is designed to control three-phase motors in variable speed drives. The package concept is specially adapted to power applications, which need good thermal conduction and electrical isolation. Infineon’s leading-edge TRENCHSTOP™ IGBTs and anti-parallel diodes are combined with an optimized & rugged SOI gate driver. The package type is DIP 36x21D and includes some of the features like inverter current rating of 30 A, over current shutdown, built-in temperature monitoring, suitable for motor power rating up to 3000 W at 10 kHz.
you can have a look at typical application circuit in below Fig.
Please go through the Product Page and Datasheet for further details
Rishabh S
My Question was how can we Add CIPOS™ IM535 Module in Infineon Designer Powered By Tina Cloud!
Is There Any Option To Add Components, What is Procedure?
Rishabh S
Any further support is required in this topic?
Regards.
Rishabh
