Translation_Bot
100 likes received
hi
Vicky.
I've changed it to 60 for the time being according to your hints. But I have a question now, because the 15V in the IPM is converted from 220 to 24V and then to 15V, and the DC310V is converted from 220V AC, so in the IPM, I've separated the 310VDC and the 15V ground of the IPM in the board, does it make sense?
And Hin/Lin is the microcontroller output PWM, this place and 220 to 24V switching power supply common ground or separate in the board to make a ground?
Since the post couldn't be replied to in the last installment, a new thread has been started in the hope that it will be seen.
I look forward to hearing from you.
thanks
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E6%99%BA%E8%83%BD%E5%8A%9F%E7%8E%87%E6%A8%A1%E5%9D%97/IPM-IGCM04G60HA/td-p/733520
Translation_Bot
100 likes received
Hello Lucas.
Kindly check the section 11.1 of a datasheet. Power ground and signal ground should be connected at a single point and it is recommended to connect them at the end of shunt resistor. It means, 310VDC ground and 15V ground shall be connected. Also, microcontroller power supply ground shall be connected with the 15V ground. Also, microcontroller power supply ground shall be connected with the 15V ground. EVAL-M1-CM610N3 I suggest you to consider EVAL-M1-CM610N3 eval board as a reference for your schematic and layout development.
(In your schematic PGND and AGND should be connected.)
Translation.
Refer to section 11.1 of the datasheet. Power ground and signal ground should be connected at a single point, and it is recommended that they be connected at the end of the shunt resistor. This means that the 310VDC ground and the 15V ground should be connected together. In addition, the microcontroller power ground should be connected to the 15V ground. Connect the EVAL-M1-CM610N3 evaluation board as a reference for schematic and layout development. (In your schematic, PGND and AGND should be connected).
Best regards, Vicky S
Vicky S
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E6%99%BA%E8%83%BD%E5%8A%9F%E7%8E%87%E6%A8%A1%E5%9D%97/IPM-IGCM04G60HA/m-p/733950
Translation_Bot
100 likes received
Hello Lucas.
Translation.
Vicky S
Translation_Bot
100 likes received
Hello @lucas741,
Could you please let us know if the provided solution resolved your query? If there is any further support you require on this topic, we'd greatly appreciate your input.
Translation:
Please let us know if the solution provided solved your problem? We would appreciate any further support you may need on this issue.
Vicky S
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E6%99%BA%E8%83%BD%E5%8A%9F%E7%8E%87%E6%A8%A1%E5%9D%97/IPM-IGCM04G60HA/m-p/736559
