I am trying to find a compatible 3 phase power supply for this board. Help would be really appreciated.
- EVAL-M1-IM828-A
Hello @Mumbasa
Please use the grid source which is available in your lab. If a three-phase grid is not available, please check with some programmable AC source vendors on the internet.
we generally don't recommend those suppliers.
Thank you
Guru
Hello @Mumbasa
Thank you for posting your question in the community.
Please elaborate on your requirements for my understanding
Thank you
Guru
Our motor is a servo which is rated at 7Amp Max consumption and 650V rated. PWM is recommended 22kHz.
Hello @Mumbasa
The EVAL-M1-IM828-A is a good choice for your application.
Please let me know what support your looking from us ?
please elaborate the what is "compatible 3 phase power supply"?
Thank you
Guru
Because EVAL-M1-IM828-A board requires power source of 3 phase.
Any power supply that can power up this model?
This Output of AC 380 V 3 phase which connects to this board.
Hope you can help me.
Hello @Mumbasa
Thank you
Guru
