IGBT Forum Discussions
User17668
5 replies posted 10 questions asked 5 questions asked
Hi Infineon,
I am working with IHV modules in the field of transportation applications.
Do you have recommendations how to apply thermal grease to IHV modules and how to mount the modules to a heat sink?
Thank you.
IGBT_Wizzard
Moderator 10 solutions authored 10 replies posted 5 solutions authored
Hi Melli,
in our internet data sheet section you will find application notes named "application and mountings instructions" for several module types.
Beside tips for handling the modules, furthermore the process of grease application and the mounting process is descibed.
As an example I attach a link to the "Application and mounting instructions for IHM and IHV modules"
https://www.infineon.com/dgdl/Infineon-Mounting_Instructions_IHM_IHV-AN-v01_01-EN.pdf?fileId=5546d46...
TS
IGBT_Wizzard
Hi Melli,
TS
