seeking for a switching devices with low on-state loss
Lius
I am now studying in area of superconducting magnetic energy storage(SMES). To realize the actual application, switching device with low on-state loss is needed. I need IGBT or Mosfet that can withstand 100V and 100A. Common IGBTs' on-state voltage drop  are about 1.3V, which is too high for superconducting magnetic. Is there any IGBTs or Mosfets with less than 0.5V on-state voltage drop?
@IGBT_JC
Rachel_G
50 likes received 250 solutions authored 250 replies posted
Hello
We recommend the IRF150P220, a 150V single N-channel power MOSFET with very low RDS(on) and optimized conduction loss. Here are main parameters: Vds=150V, ID (@25°C)max=203A. Rdson=2.7mΩ@10V max. You can refer to the datasheet for further information, here is the link:
https://www.infineon.com/cms/en/product/power/mosfet/n-channel/irf150p220/
Rachel
Rachel_G
Hello
Rachel
IGBT_JC
10 sign-ins First question asked 5 solutions authored
Hi Lius,
Please check the Infineon's 100V power MOSFETs portfolio, for sure you will find a proper MOSFET that fit your requirements (ID, RDSON, package, etc.) : https://www.infineon.com/cms/en/product/power/mosfet/
A possible proposal based in your brief requirements info: https://www.infineon.com/dgdl/Infineon-IRF100P218-DataSheet-v02_01-EN.pdf?fileId=5546d462602a9dc8016...
I hope this helps, but let me know if any additional info is needed.
Thank you
Lius
Thanks. But single MOSFET is not convenient in application. Is there any MOSFET module and corresponding driver?
Rachel_G
Dear
We don't have power mosfet module now. And share you an AN about gate driver selection guide for your reference. Here is the link:
https://www.infineon.com/dgdl/Infineon-EiceDRIVER_Gate_Driver_ICs-ProductSelectionGuide-v02_00-EN.pd...
Rachel
