User17671
04:58 AM
- Email to a Friend
Hi all,
I have a short question. What are the pros and cons for the half-bridge topology compared to the single ended one in induction cookers?
Thanks in advance!
Thanks in advance!
Thomas_Patrick_
05:07 AM
- Email to a Friend
The half bridge topology offers quite some advantages compared to the SEPR topology, but also some disadvantages:
Pros:
↑ Very good power efficiency for wide load range (capacitive operation with ZV-turn-off and ZV-turn-on)
↑ Easy to control due to stable VCE voltage
↑ Higher reliability than SE due to less sensitivity on control errors
↑ IGBT are operated from rectified line -> lower voltage class IGBTs can be used
↑ Higher output power capability -> no limitation for output power
↑ Continuous operation at lower power levels
Cons:
↓ More expensive than SEPR due to two power switches and Half Bridge Driver
↓ Larger heatsink and PCB needed
I hope this can help you for deciding which topology to choose.
Thomas Wurzer
Pros:
Cons:
Thomas Wurzer
Thomas_Patrick_
05:07 AM
- Email to a Friend
Pros:
Cons:
Thomas Wurzer
Pros:
Cons:
Thomas Wurzer
User17671
05:34 AM
- Email to a Friend
thanks for this fast response. yes - it's very helpful
