User17676
10 questions asked 5 questions asked First question asked
In the used DC link design of the resulting losses (Eon and Eoff) differ from the datasheet values given by Infineon. Why are the losses different?
Guru_Prasad
250 replies posted 100 solutions authored 25 likes received
Hello User17676
Thanks for writing us.
The Datasheet Eon and Eoff are calculated at some particular temperature, Gate resistance, DC link voltage  and  stray inductance of your busbar. If you make your own test setup as per datasheet sheet test condition you will see same losses.
Guru
Guru_Prasad
Hello User17676
Guru
