UL QQQX2
MS_19060803
Distributor - TED (Japan)
25 likes received 25 solutions authored 10 likes given
Hi all,
Could you please tell me if IKA15N65ET6 conforms to UL QQQX2?
Also, please let me know if there is a way to check it by myself.
MS
Hello @MS_19060803
I was asked to you check both standards or same or not. any way that product series was qualified for  UL QQQX2, you can see my attachment on the previous post.
Guru
Guru_Prasad
250 replies posted 100 solutions authored 25 likes received
Hello @MS_19060803
Thanks for posting your question in the Infineon community.
The IKA15N65ET6 tested for JEDEC47/20/22, please compare your UL QQQX2 standards with JEDEC47/20/22 if it is
matching it will be fine. or you can check in UL products website also I have check it is showing in website.
Guru
MS_19060803
Do you mean that the UL QQQX2 standards is the same JEDEC47/20/22?          I checked UL products website. However, I could not find the IKA15N65ET6.           Did you find that in the website?
Best regards,                                     MS
Hello @MS_19060803
Guru
