- Email to a Friend
Hello.
I want to know Tolerance of IGBT FF1800R12IE5.
Please see the number in the square.
Thank you.
- Email to a Friend
Hello @ygpark2
Thanks for posting your question In the Infineon community.
Generally, those tolerances will not contribute much anyway the explanation given below
Those marked tolerances are to be considered based on hole tolerances. you can consider the
below tolerance and add to your individual lengths based on the number of holes
May I know which datasheet you have considered please share the link
let me know if you need any additional details
Guru
- Email to a Friend
Hello @ygpark2
Guru
- Email to a Friend
I want to know tolerance of the number in the square.
I guess it is from ISO 2768.
Is it class fine or medium?
- Email to a Friend
Hello @ygpark2
I mentioned in my previous post you need to calculate it based on hole tolerances. Looks like you are looking for different information.
May I know your exact question and a little bit explanation of your requirement?
I want to check may I know why are you referring to ISO 2768? and how it(Is it class fine or medium?)will help for
tolerance calculation of the data provided in a datasheet?
Thank you
Guru
