Hello ALL,
in the software, there is a setting page about the basic working params of the system, shows below,
question, what is the meaning of Switching Frequency?
carrier signal frequency or IGBT gate switching frequency?
Thank you
Hi @FanLee
Thanks for posting on the Infineon community page.
Switching frequency is defined as the rate at which the switching device (IGBT or MOSFET) is turned on and off.
Here the carrier signal frequency and IGBT gate switching frequency are the same. Refer to the attached image from the IPOSIM information tab.
Akhil Kumar.
Hi @FanLee
Akhil Kumar.
Thank you, Akhil Kumar, for your quick reply.
