Our company is sourcing for 5-6KW, 220V single phrase induction heating controller (Use in UL/ETL certifided machine), can anyone suggest manufacturer can provide this product?
我公司正在采购5-6KW,220V单相电磁炉机芯(用于UL/ETL认证机器),能推荐制造商可以提供这种产品?
Hi KTLee,
Infineon can offer the total solution for the induction cooktop. The following is the Induction cooking system diagram for your reference.
For microcontrollers, recommend you the CY8C6316BZI-BLF03: Connectivity line - dual core, highly optimized, flexible and ultra-low power, Machine learning ready Microcontroller with Bluetooth® Low Energy for IoT applications.
For power device, recommend you the IHW40N65R6: Reverse Conducting R6 650 V, 40 A IGBT in TO-247 package with monolithically integrated diode is designed to fulfill demanding requirements of induction heating applications using half-bridge resonant topology.
https://www.infineon.com/cms/en/product/power/igbt/igbt-discretes/ihw40n65r6/
For driver, recommend you the 2ED21824S06J:650 V, 2.5 A high current half-bridge gate driver IC with integrated bootstrap diode in DSO-14 package.
https://www.infineon.com/cms/en/product/power/gate-driver-ics/2ed21824s06j/
If you need other products technical support related to the induction cooktop application, please let me know.
Rachel
Hi Rachel,
拓扑是指控制方式?
控制(Control protocol):RS485
输入(Input):220VAC ,單相(Single phase)
功率(Power):5-6kW
频率(Frequency): around 16-20kHz
效率没特别要求(No special requirements for efficiency)
KT
Hi KTLee,
Rachel
Dear Rachel,
Thank you for your reply. I am looking for an end product (image below), we don't make our own induction heating controller. Since infineon is one of the top IGBT provider, I believe that infineon will know some downstream manufacturers that can fullfill our reqirement.
Hi KTLee,
For information related to downstream manufacturers, please contact the Infineon local sales or FAE.
Rachel
