MS_19060803
Distributor - TED (Japan)
25 likes received 25 solutions authored 10 likes given
Hi all,
Can the SPICE model of IKW40N120H3 be used with LTSPICE (manufactured by ANALOG DEVICES)?
If possible, could you please teach me how to do it?
MS
akbarsyeda
First question asked First solution authored First reply posted
Hello all,
Let me clarify the answer
Yes, the SPICE model of the IKW40N120H3 (and all other Infineon discrete IGBTs in general) is compatible with all SPICE simulators including LTSPICE.
To learn how to use the model in a simulation tool (such as LTspice and SIMetrix), please refer to the following application note:
https://www.infineon.com/dgdl/Infineon-AN_2020_17_Simulation_models_of_IGBTs_and_power_silicon_diode...
This provides a detailed explanation of the simulation models offered by infineon and also shows step-by-step instructions for using the simulation model in LTspice.
Thank you.
Qurat
AZIZ_HASSAN
5 likes given 250 sign-ins 100 solutions authored
Thank you for posting on Infineon community.
Since, the spice model package doesn't specify its compatibility, I request you to run it once in LTSPICE.
If it shows  a error of unrecognized sub circuit error, then kit is not compatible with LT SPICE.
BR,
AZIZ HASSAN
akbarsyeda
Hello all,
Thank you.
Qurat
