User17640
10:46 PM
- Email to a Friend
Dears,
can anybody tell me how to figure out the right Rg for drive applications?
Ty
Max
Ty
Max
02:36 AM
- Email to a Friend
Hi Max,
For drive applications it is important that du/dt is in the range of 2kV/us-8kV/us (depending on the rated motor voltage), higher values can endanger coil insulation and bearings.
Typically for <460V motor rated voltage the maximum of 5 kV/µs for the inverter output voltage is required.
To chose the right Rg value for IGBT7 based module please use the graph from the datasheet. This diagram enables an easy choice of Rg to match the right gate resistor for specified dv/dt.
BR
BR
02:36 AM
- Email to a Friend
Hi Max,
BR
BR
