sa_443
Can the Press-Pack IGBT P3000ZL45X168 block reverse voltages? We need it to be able to block a positive voltage from Emitter to Collector in a particular application and so need to know if this is a reverse-blocking (non-punch through) IGBT.
Guru_Prasad
250 replies posted 100 solutions authored 25 likes received
Hello @sa_443
Thanks for posting your question
The blocking voltage for positive Vce is 4.5kV
The blocking voltage for negative Vce is not guaranteed for 4.5kV
Please let me know your application we will provide the recommendations
Guru
Guru_Prasad
Hello @sa_443
Guru
Do you guys have a spec for the blocking voltage capability?
Guru_Prasad
Hello @sa_443
For the requested data we did not do testing. hence we will not provide the data.
Guru
