- Email to a Friend
I have used FF600R12ME4P-B11 in my series product in the past but this one is not available now. Can you suggest a replacement for this?
Thanks .
Tanvi Mahajan
IGBT
- Email to a Friend
Hi Tanvi,
Per your request I feel FF600R12ME4P_B72 is good to go as a alternate part number.
For more information please refer my earlier post.
BR,
AZIZ HASSAN
- Email to a Friend
Thank you for posting on Infineon community.
In order to provide a suitable alternative part , I request you to provide information regarding following points.
1) What is your application.
2) Do you need the same features(like NTC, terminal connection) provided in the part number which you were using in past.
3) Do you want one to one replacement (same size and foot print).
BR,
AZIZ HASSAN
- Email to a Friend
Meanwhile we are suggesting you an alternate part number with one to one replacement in terms of electrical and mechanical parameters.
FF600R12ME4P_B72 is the alternate part number.
Only difference between two part number is the construction variation. PFA to understand the nomenclature.
BR,
AZIZ HASSAN
- Email to a Friend
Hello Aziz
1. Application is Inverter for motor testing (standalone not automotive). It will come under industrial application.
2. Same product features is preferred.
3. Footprint match and same pin to pin configuration is must.
Thank you.
- Email to a Friend
Hi Tanvi,
BR,
AZIZ HASSAN
- Email to a Friend
Can you suggest gate driver module for this IGBT ?
We were using 2SP0115T2B0-FF600R12ME4 earlier. Do you have anything on similar grounds?
- Email to a Friend
May I know which gate driver module you were using earlier, please share complete details so that I can check whether same can work or not.
Probably same gate driver will work.
BR,
AZIZ HASSAN
- Email to a Friend
Can you please tell about the availability of this product ?
No of pieces: 60
Lead time
- Email to a Friend
The gate driver I have checked, same is fine for B72 as well.
Note- In both IGBT, you can see small change in Rth (thermal resistance) value which I believe will not make more than 2 degree difference at the junction.
Regarding the stock update let me check with other team.
BR,
AZIZ HASSAN
- Email to a Friend
The previous part number of gate driver is not in stock . Can you check this one
- Email to a Friend
The proper replacement for part number FF600R12ME4P_B11 based upon availability and other parameters is FF600R12ME4_B73.
Regrading gate driver I request you to share the gate driver part which is available for for in market and I will confirm it.
BR,
AZIZ HASSAN
