Hi all,
I am looking to fix up a plasma cutter that has a blown IRG4PSC71U IGBT on it. Problem is that the component is out of production and I am not a component SME by any means. Could anyone recommend a replacement IGBT that would be ideally a drop in replacement?
Thank you
ispn:12222:1:0
l1:144:1:0
l2:219:1:0
l3:220:1:0
Hi pol_tech,
Recommend you the IKW50N65ES5 to replace for IRG4PSC71U. Here is the link of replacement information: https://www.infineon.com/cms/en/search.html#!view=discontinued&term=IRG4PSC71U
And you can find more information related to IKW50N65ES5 in the datasheet.
Rachel
Hi pol_tech,
Rachel
