IGBT Forum Discussions
pllan815
First reply posted First question asked First like given
In IGBT datasheet, what are the definitions of Qrr, tr, and tf? For Qrr, what kind of definition does it correspond to?5345.attach. Thanks in advance.
IGBT_Wizzard
Moderator 10 solutions authored 10 replies posted 5 solutions authored
Hallo pllan815,
please have a look into our Infineon Application note 2011_05:
https://www.infineon.com/dgdl/Infineon-AN2011_05_IGBT_Modules_Explanation-AN-v01_02-EN.pdf?fileId=db...
Definitions for the dynamic parameters tr and tf you find in chapter "3.10 Dynamic behavior".
In chapter "4.4. Reverse recovery" you will find the definition for Qrr.
Be aware, that different upper integration limits might be used by our competition.
Your attached pictures show alternative ways, e.g. integration up 10% IRM.
Infineon uses a integration limit up to 2% IRM to cover the whole recovery process.
TS
IGBT_Wizzard
Hallo pllan815,
TS
pllan815
Thank you for your answer!
pllan815
Thank you for your answer! Now, I know the definition of Qrr, tr and tf. But, I don't find the information for trr. Can I assume that the value of trr is equal to (t2 - t‘) in the graph. 5276.attach
IGBT_Wizzard
Yes, you are right.
trr represents the duration of the occurrence of reverse recovery current. it is measured from the point of time, where the current crosses the zero line up to 2% IRM.
TS
