01:16 PM
- Email to a Friend
I'm trying to simulate the IKW40N120H3 IGBT using Capture/PSpice 16.5, and I get the following error message
ERROR(ORPSIM-15108): Subcircuit L4XXXB_Lh3 used by X_Z1.XDIO is undefinedd
I've add the IFX_N120H3.lib into the simulation profile as a global library.
I'm not sure where the problem can be.
forix
12:43 AM
- Email to a Friend
Dear Guz21,
thank you for your thread. May be there is a typo in L4XXXB_Lh3. Please check and replace string "L4XXXB_Lh3" by string "L4XXXB_L2h3" (line 81 in file IFX_N120H3.lib).
If this does not solve the problem (spice model of IKW40N120H3 IGBT) we suggest to go to your tool partner. Thank you.
forix
12:43 AM
- Email to a Friend
Dear Guz21,
10:43 AM
- Email to a Friend
Thanks Bernd,
I stopped getting that error, replacing the line worked, but now I'm getting another error with the same model.
I'm getting this error now:
INTERNAL ERROR -- Overflow in device X_Z1.XDIO.GV1, Convert
I've checked the ground paths and I've made sure that everything is grounded and has a zero reference, but I'm still getting that error.
After changing line 21 from the library file now line 81 looks like this:
Line 81: XDIO katl anol L4XXXB_L2h3 PARAMS: TJ = {TJ} A=0.05638 N_ideal = 1.0
this is where the XDIO variable is defined, I'm quite new to pspice so I'm not able to see anything wrong with that line of code
Thanks, David
Thanks, David
User270
Mar 04, 2012
09:21 PM
- Email to a Friend
Hi Guz21,
I checked with Pspice Student (cadence) and corrected the problem with the lib file.
The only thing I have changed was the following (It was already proposed above) and it worked pretty well.
[old line 81] XDIO katl anol L4XXXB_Lh3 PARAMS: TJ = {TJ} A=0.05638 N_ideal = 1.0
[new line 81] XDIO katl anol L4XXXB_L2h3 PARAMS: TJ = {TJ} A=0.05638 N_ideal = 1.0
Do you have new findings?
forix
10:30 PM
- Email to a Friend
Thanks to forix for confirmation. Such an overflow error can also be caused by simulaton porfile exceeding a model parameter.
