IGBT Forum Discussions
Fränce
Moderator 5 sign-ins 5 replies posted 10 questions asked
Good morning 🙂
What is the maximum allowed thermal interface temperature for 175°C Primepack modules with IGBT5 and .XT.
In particular for the FF1800R17IP5P.
IGBT_Wizzard
Moderator 10 solutions authored 10 replies posted 5 solutions authored
Fränce wrote:
Good morning 🙂
Hi Fränce,
the IFX specific thermal interface material TIM (module names with pre-applied material use the extension...P) is qualified up to a continous base plate temperature of Tc=150°C. The IFX-Tim temperature specification is given in the module datasheets with TIM and in the AN2012-07 Rev.2.1
TS
Fränce
One more Question regarding IGBT 5 and XT... Could you please elaborate on the advantages of IGBT5/.XT modules compared to modules with standard joining technology?
Do you have any documentation about this technology?
IGBT_Wizzard
Fränce wrote:
Good morning 🙂
Hi Fränce,
TS
IGBT_Wizzard
Hi Fränce,
all IGBT5/.XT power modules can be used up to a junction temperature of Tvj=175°C.
Beside further advantages and based on this the biggest adantage is given by the higher robustness against load cycling.
In life time consuming applications e.g. Windturbine converter, CAV or traction the IGBT5/.XT power modules will result in a significant higher robustness against cycling load.
If you have further questions regarding IGBT5/:XT, let me know ....
TS
