TechGuru
5 sign-ins First question asked Welcome!
Hi community,
There can be typically two cases for IGBT power modules with bondwires.
1. Direct sense wire on semiconductor for Vce measurement
2. No direct sense, but sense of Vce on DCB through load bondwires
During Rth measurement (Rth=Tvj-Tc/Ploss), Ploss is directly dependent on current and on-state voltage drop Vce.
My question would be,
From above two cases, Case 1 Vce measured will be slightly lower than Vce measured during case 2 because, Vce in case 2 also includes load wirebonds drop. Therefore Rth_case 1 will be slightly higher than Rth_case 2.
Which one of this is correct? Any inputs on this is highly appreciated. Thank you.
Santhoshkumar
100 replies posted 50 solutions authored 250 sign-ins
Dear @TechGuru ,
Greetings from Infineon,
Thanks for posting your query in Infineon community.
Please find our recommendations while measuring the Rth in this here (AN2015-10)
Kindly let us know if you have any further queries,
Santhosh Kumar
Santhoshkumar
Dear @TechGuru ,
Santhosh Kumar
SEONGHUNPARK
Distributor - Changnam (South Korea)
First solution authored 10 sign-ins First question asked
This document is helful for me
Thanks .
