- Email to a Friend
Need to know the Case material and the minimum thickness for IKW75N60T for UL purposes. Can you please provide?
Here is the exact request:
“The standard requires epoxy that is 0.7mm thick. Your manufacturer would then need to provide evidence/documentation to the UL inspector that the case is constructed with epoxy that is 0.7mm minimum thick.”
Please provide information to support this request for IKW75N60T. Thank you.
- Email to a Friend
Hi @CDarrow,
Thanks for posting your query in the Infineon community.
"The part (IKW75N60T) that you mentioned in the request is not covered by this UL certification as they are not isolated packages, they have an exposed lead frame on the back side."
For material & its thickness details are quite confidential and cannot be shared in this forum.
For the above details please contact your local FAEs.
thanks
malleswararao
- Email to a Friend
Hi @CDarrow,
thanks
malleswararao
