04:26 AM
- Email to a Friend
How does the Miller plateau level of an IGBT relate to the load current?
Thank you! 🙂
Thank you! 🙂
akbarsyeda
12:44 AM
- Email to a Friend
Hello Fränce,
During the switching transition, the device operates in active region, the current through the device is proportional to the gate emitter voltage (as can be seen in the figure below) and can be given as: Ic ~ gfs*Vge (where gfs is the transconductance of the device). This shows, in order to allow a higher current through the device, the gate-emitter voltage should be high.
Let’s take the example of turn-on transition, the IGBT begins to conduct when the gate-emitter voltage rises above the threshold voltage. Vge continues to rise until the plateau region is reached, where the current through the device reaches its steady state value (that is determined by the load current). Hence, Vge_plateau settles to a value that allows the IGBT to deliver the load current. Evidently, when the load current is high, Vge plateau level is also high.
Hope this helps.
Qurat
Hope this helps.
Qurat
akbarsyeda
12:44 AM
- Email to a Friend
Hello Fränce,
Hope this helps.
Qurat
Hope this helps.
Qurat
