IGBT Forum Discussions
currego
First question asked Welcome!
Dear Infineon Community,
What is the maximum power and voltage manage by a VSC HVDC converter with Infinieon IGBT modules?
Can you give a list of HVDC projects developed with Infinieon IGBT modules?
BandaruAkhil
Moderator 50 sign-ins 25 replies posted 10 solutions authored
Hi @currego
Thanks for posting on the Infineon community page.
Infineon has a maximum voltage of 6500 V  and a current of 3600 A in the IGBT modules (two different
modules). The most popular one for HVDC application is 4500 V and 1200 A IGBT module used by many
customers. Please use the link to filter and select the IGBT modules. Depending upon the application configure
them in series and parallel.
Please refer the attached link for more information also refer the Infineon page for the IGBT modules.
Infineon doesn't have the documents/Eval Boards at the moment. We are ready to give technical support if required.
Akhil Kumar.
BandaruAkhil
Hi @currego
Akhil Kumar.
