User20724
08:57 PM
- Email to a Friend
ipw90r340c3用于dcdc全桥电路上,全桥拓扑的输入电压500vå·¦å³ï¼Œ
一个产å“用4个ipw90r340c3,分别为q0500,q0501,q0502,q0503。
s101å’Œs103引脚接å˜åŽ‹å™¨çš„ä¸»è¾¹ï¼Œå˜åŽ‹å™¨çš„å‰¯è¾¹æŽ¥åŒæ¥æ•´æµç”µè·¯è¾“出24v,å˜åŽ‹å™¨åŒæ•°æ¯”为12:1
æŸå的时候一般是在满载工作时æŸå,器件æŸå时测试ds级çŸè·¯ã€‚
且该器件æŸå时都是上桥两个器件(q0500,q0502ï¼‰åŒæ—¶æŸå,
器件æŸå之åŽåªæ›´æ¢å¯¹åº”ä¸¤ä¸ªå™¨ä»¶ï¼Œå†æµ‹è¯•,能æ£å¸¸å¸¦æ»¡è½½ï¼Œ
且æŒç»é•¿æ—¶é—´æµ‹è¯•也ä¸å†å‡ºçްæŸå,
测é‡å™¨ä»¶å³°å€¼ç”µåŽ‹å’Œç”µæµéƒ½æ˜¯æ£å¸¸çš„ï¼Œæ‰€ä»¥æ— æ³•æŠ“åˆ°æŸåçž¬é—´çš„ç”µåŽ‹ç”µæµæƒ…况。
请å助分æžä¸‹å¼‚å¸¸åŽŸå› ï¼Ÿç”µè·¯æ–¹é¢è®¾è®¡æ˜¯å¦åˆç†ï¼Ÿä»¥åŠæ”¹å–„措施?
User20724
08:59 PM
- Email to a Friend
ipw90r340c3 应用电路ä¸ï¼Œè¾“入电压500v ,选型是å¦åˆç†ï¼Ÿ
ciji_4336356
Nov 30, 2020
05:20 AM
- Email to a Friend
您好,请问您是否可以用英语重复下您的问题,谢谢。
User20724
11:07 PM
- Email to a Friend
IPW90R340C3 the devices used in DCDC full bridge circuit, full bridge topology circuit,
Input voltage 500 v,
A product with 4 IPW90R340C3, location is Q0500 Q0501, Q0502, Q0503
(bridge circuit on Q0500 Q0502) often is damaged, defective rate 1%。
(Q0500 Q0502) to replace two new devices, test, load can work normally.
And test for a relatively long time also no longer appear damaged, measuring device peak voltage and current are normal。
What reason? How to improve?
User20724
11:08 PM
- Email to a Friend
circlejhx wrote:
您好,请问您是å¦å¯ä»¥ç”¨è‹±è¯é‡å¤ä¸‹æ‚¨çš„问题,谢谢。
