The EV market is bigger and better than ever. Join the EV Webinar to find out how you could best utiilize IGBT for EVs.
IGBT Forum Discussions
alpix06
Hello
I'm calling from 30-pt12nma 100sc01 coded module. Can you help? ?
30-PT12NMA100SC01
M848F01Y01 2816
VIN 48878 0679
MODULE WITH CODE
Detailed Photos are attached.
Good work.
1211Shukla
25 solutions authored 100 sign-ins 50 replies posted
Since there is no response from your side, I am closing the ticket.
Rishabh
1211Shukla
Can you elaborate your issue?
Rishabh
I'M LOOKING FOR THE IGBT MODULE I SHOWED IN THE PHOTOS.
1211Shukla
We do not have any IGBT with respect to image shared by you in Infineon portfolio. Are you sure it is Infineon product? If you can share me the specification or system requirement, I will be able to recommend you one.
Rishabh
Hello
must be in the same pin spacing. I can send you this product, can we do the same?
special production 100 Ampere 1200 Volt
1211Shukla
Sorry for the delayed response, I was out of office, Can you send me the exact pin configuration and spacing, better if you can send me any  specification document.
Rishabh
1211Shukla
Can you please reply with the required information?
Rishabh
1211Shukla
Rishabh
