I am working on IPOSIM to understand IGBT junction temperature stress. Regarding "predefined Heatsink" with cooling method Water, it has Rth hs (K/W), is this per IGBT or diode or combined module case to ambient?
Thank you!
- IPOSIM
Hi @Rakeshelct
Thanks for posting on the Infineon community page.
The mentioned Rth is for heat sink per IGBT and Diode.
Akhil Kumar.
Hi @Rakeshelct
Thermal resistance (Rth) is mentioned per IGBT and diode. Please do refer to the datasheet for values. IPOSIM
also considers the same.
Akhil Kumar
Hi @Rakeshelct
Akhil Kumar.
Ok, now I got this.. For 6 switch module, i need to apply factor 6 on the overall heatsink Rth value. Thanks!
