Need some explanation about datasheet of IKCM20R60GD.
IGBT
ispn:8433:1:0
l1:144:1:0
l2:231:1:0
IKCM20R60GD is an IPM solution intended for use in switched reluctance motor applications.
"Can I open both High A and Low B IGBTs or internal logic blocks it?"
In the above sentence do you mean that you are referring to using both the Hi and LO blocks separately?
Abhilash P
Hi, guys. I can't get enough information from datasheet. Can I use module IKCM20R60GD to 1 phase AC motors or it may be used for Switched Reluctance Motor? Can I open both High A and Low B IGBTs or internal logic blocks it?
Abhilash P
Yesterday we successfully designed a variable frequency driver for asynchronous motors with phase-shifting capacitor on IKCM20R60GD. Transistors are connected as full bridge
A_high B_high
B_low A_low
With such a connection power module works correctly with asynchronous motors. Thanks for your answer!
