Wano2047
Need some explanation about datasheet of IKCM20R60GD.
Abhilash_P
50 likes received 500 replies posted 250 solutions authored
    IKCM20R60GD is an IPM solution intended for use in switched reluctance motor applications.
"Can I open both High A and Low B IGBTs or internal logic blocks it?"
             In the above sentence do you mean that you are referring to using both the Hi and LO blocks separately?
Abhilash P
Wano2047
Hi, guys. I can't get enough information from datasheet. Can I use  module IKCM20R60GD to 1 phase AC motors or it may be used for Switched Reluctance Motor? Can I open both High A and Low B IGBTs or internal logic blocks it?
Abhilash_P
Abhilash P
Yesterday we successfully designed a variable frequency driver for asynchronous motors with phase-shifting capacitor on IKCM20R60GD. Transistors are connected as full bridge
A_high   B_high
B_low    A_low
With such a connection power module works correctly with asynchronous motors. Thanks for your answer!
