Translation_Bot
The Spice L2 model of the IKW75N65ES5 IGBT model cannot be opened using simetrix software. The inside is like this. How do I process it before I can use it?
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/IGBT/IGBT-%E7%9A%84spice%E6%A8%A1%E5%9E%8B/td-p/653345
Translation_Bot
Hello
Please try the exciting steps,
1. Create a new schematic and press F11 to open the command window Add a line of code about the address of the path to the model you saved, as shown below:
2. Build a Circuit, Place an IGBT Symbol with Place --> From Symbol Library... --> Semiconductors --> IGBT
3. Right click the IGBT symbol --> Edit/Add properties --> change the value to SUBCKT name (e.g.
IGB15N65S5_L2)
4. Setup simulator and run
Best dressing,
Rachel
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/IGBT/IGBT-%E7%9A%84spice%E6%A8%A1%E5%9E%8B/m-p/653782
Translation_Bot
Hello
IGB15N65S5_L2)
Best dressing,
Rachel
