I have a yaskawa vfd which has proper incoming voltage but faults out for IGBT short circuit as soon as it’s started. We tried a another old vfd which had been sitting in the storeroom for long time but that gives the same fault?
IGBT
Thanks for posting on the Infineon community page.
Before changing the IGBT please check the below parameters
- Blocking voltage (Vce)
- Collector Current
- Gate charge
- Gate resistors
- Gate to Emitter voltages
- Gate Peak current
- Saturation voltage
- Switching Energy (Eon & Eoff)
- Thermal resistance
- Temperature rise
If the above-mentioned parameters are under limits, ensure that gate pulses are proper.
Share the schematic of VFD, Infineon IGBT, and driver part numbers to verify.
Akhil Kumar.
- Collector Current
- Gate charge
- Gate resistors
- Gate Peak current
- Temperature rise
Akhil Kumar.
