IGBT Forum Discussions
User21161
Dear All,
I am wondering the SC data in the IGBT datasheet.
For example, when the SC data is set as 9500A in the datasheet, does it mean when the SC current reaches 9500A, the IGBT will be de-saturated?
4947.attach
Br
Sand
IGBT_Wizzard
Moderator 10 solutions authored 10 replies posted 5 solutions authored
Hallo Sand,
the SC value given in the data sheet represents the current value reached under SC1 conditions.
A typical measurement could look like this:
CE voltage (blue)
SC current (red)
gate voltage (green)
4948.attach
As you can see in the measurement above, the CE voltage never reaches a saturated level, the IGBT stays de-saturated.
The specified SC value can be derived from the cross point of the rising and falling current slopes.
BR
IGBT Wizzard
TS
IGBT_Wizzard
Hallo Sand,
CE voltage (blue)
SC current (red)
4948.attach
BR
IGBT Wizzard
TS
