IGBT Forum Discussions
We are using IGBT module f4-75r06w1e3 for a three phase inverter application. We
have well tested gate driver based on IR2110 wich is isolated by VO3120 opto isolator. H bridge has RCD clamping snubber as well. it works properly at our full load condition with out transformer at
the output. When we connect the transformer at the AC output our module getting damaged. Can you please help me
to track the issue?
Guru_Prasad
Moderator 100 replies posted First question asked 10 likes received
Hello @User19042
Thanks for posting your question in the Infineon community.
The below reasons can damage your IGBTs when you connect the transformer to H-bridge
1)The Freewheeling current can damage. The freewheeling  current will flow when switch is turned OFF. The
free wheeling current mainly depends on the transformer leakage inductance, current raise, switching
frequency and modulation index.
2)While the transformer saturates then also the IGBT can damage. while transformer saturates the di/dt will
flow in IGBT.
Guru
User9050
We have recognized that you have started discussion with technical support team via http://www.infineon.com/productsupport. I suggest to continue there and you may post a possible soultion later on.
Schulz
User19042
hi,
I would like to know wether this issue got resovled or not. I am also facing the same issue. I am using tis for single phase inverter with HCPL316J and the IGBT module keeps going bad.
Guru_Prasad
Hello @User19042
flow in IGBT.
Guru
