- Email to a Friend
My customer ask me the question whether Infineon can provide Spice Model data of IGBT module which can work with Ansys simulator which customer is using now. Customer acknowledge Infineon has "IPOSIM" but this is not enough for customer.
IGBT
- Email to a Friend
Thanks for your patience.
As per our internal discussion , I am really sorry that we cant share the spice model of the IGBT because it might not be compatible with other software (like Ansys).
However, to select a right module, we recommend that you use IPOSIM.
Another option is that, we can provide the PLECS model( same model which we have integrated in IPOSIM).This model is based on module characteristic but not sure whether it can be integrated with Ansys or not.
BR,
AZIZ HASSAN
- Email to a Friend
May I know the application and part number of the IGBT for which you are asking Spice model .
- Email to a Friend
Customer is now under investigating which IGBT module supplier must be choose for their next next model servo amp. So at this moment, no specific part number that they are thinking but they may looking for 650V/300A,400A,600A and 1200V/200A,300A,400A. All two in one type.
For their future IGBT module selection, it is important to run Spice Model which can eliminate their development period, they don't want to do any cut and try style for their future model development.
Support of Spice Model would be key factor to select IGBT module supplier.
Pls note that competitor Fuji CAN NOT support this customer's requirement now.
- Email to a Friend
Thank you for your explanation.
Since, this spice model is confidential matter, i request you to crease a case on Mycases system so that we can support you in confidential manner.
I hope you understand.
AZIZ HASSAN
- Email to a Friend
BR,
AZIZ HASSAN
