IGBT junction temperature experiment
Translation_Bot
Dear Infineon,
Hello, I am a master's student, and my research direction is IGBT device stability, and the current research target component selection is IKW75N65ET7. When it comes to device junction temperature analysis research, I have a question for you. Is there any relevant data of this type of IGBT, in which the gate voltage is 20V, when the collector current is 5-75A, the collecting collector voltage at 25°C to 175°C, if so, can you provide it, if not, can you provide relevant experimental services, if you can provide experimental services, how do I need to contact you
We look forward to hearing from you, thank you
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/IGBT/IGBT-junction-temperature-experiment/td-p/651391
Translation_Bot
Dear @SiCk
Greetings from the Infineon
In the simulation, we may not have the effects of the parasitics, but when it comes to actually discover the parasitics will play some roles.
So Experimental Results Depend on the Test Setup
I hope this is enough for your question
thank you
Best Housekeeping,
Siva Naga Malleswararao.
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/IGBT/IGBT-junction-temperature-experiment/m-p/652886
Translation_Bot
Dear @SiCk
The data is there in the device datasheet page no. 9. For your reference please see the picture below
By using the above graphs, you can retrieve VCE data as per your intentions.
thank you
Best Housekeeping,
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/IGBT/IGBT-junction-temperature-experiment/m-p/651525
Translation_Bot
Dear Infineon
Thank you very much for your reply
The Reference Data You're Very Helpful.Once Again, I Would Like to Express My Gratitude Gratitude.I still have some questions, for IKW75N65ET7 relevant data, I have simulated in LTspice Through the spice model you asked, I would like to ask, how much error will be between the relevant data simulated in this software and the relevant data simulation from actual diagnosis.
We look forward to your reply, thank you
Your product obsessive,
Sick
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/IGBT/IGBT-junction-temperature-experiment/m-p/652140
Translation_Bot
Dear @SiCk
thank you
Best Housekeeping,
