IGBT driver ringing
Raja22028
First like given 5 replies posted 5 sign-ins
I am testing the 1ED3123MC12H driver IC with IGBT  IKW15N120BH6  using Buck converter circuit. Vdc=30V, 0.6mH and Fsw=10 kHz. But the ringing is creating a problem. Any suggestions pl
Pablo_EG
First question asked 250 sign-ins 250 replies posted
Hello Raja22028,
Thank you for posting on Infineon Community.
We understand that you are experiencing heavy ringing in your driver/IGBT setup.
Could you let us know if this ringing is produced while the gate signal is ON, or when the signal turns OFF?
As this is a buck topology, the switching node (emitter of IGBT) will fluctuate from 30V to around 0V.
This fluctuation could be the reason for the ringing.
Could you try:
-Disconnecting the GND of the +15/-8 DC/DC converters.
-Connecting the GND of the +15/-8 DC/DC converters to the switching node (emitter of IGBT).
Pablo
Pablo_EG
Hello Raja22028,
Could you try:
Pablo
with 50% duty cycle, while I am about to turnoff it is happening
Raja22028
Sure Pablo. I will give a try and let you know the status.
Pablo_EG
Hello Raja,
Do we have an update on the status of your issue?
Let us know if it was solved or if you require further help.
Bets regards,
Pablo
Yes my problem is solved. thank you
