hungtv84
First question asked Welcome!
Hi, I'm currently use IGBT modules FS25R12W1T7BOMA1 for application PMSM Driver, the motor is PMSM motor 380VAC, 3A nominated, Vmax 3000rpm. The DC bus input is 600VDC and Power max of Driver is 3000W in 5 sec ~ 9A maximum. The Driver will run continuously with 600W.
Is using IGBT module FS25R12W1T7BOMA1 good for technical standard above. Do you have any recommendation ?
Thank you
Guru_Prasad
250 replies posted 100 solutions authored 25 likes received
Dear @hungtv84
Greetings!
have you tried any power loss simulations?
I hope you have done this analysis in IPOSIM simulation?
https://iposim.infineon.com/application/
The IGBT will be conformed by looking junction temperature and type of cooling . over loading current capability .  for normally current rating the selected IGBT module is okay
Thank you
Guru
Guru_Prasad
Dear @hungtv84
Greetings!
Thank you
Guru
