Dine_infin
Distributor
50 sign-ins First like received 10 questions asked
Hi Team ,
Can we turn off IGBT  module when gate voltage pulse is Zero .
BR
Dine
Guru_Prasad
250 replies posted 100 solutions authored 25 likes received
Dear @Dine_infin
Greetings!
Only zero volts will not turn off the IGBT and it will have some charge in the gate, this charge may cause for false turn-on. The negative voltage is required to turn off the IGBT fully.
Thank you
Guru
Guru_Prasad
Dear @Dine_infin
Greetings!
Thank you
Guru
