Iancalazans
First like given 5 sign-ins First reply posted
              We have the IGBT model FF650R17IE4 installed in PV inverters, and during some tests we had some doubts, can you please help us?
  • Do you have any value of resistance that is acceptable of the following parts:
    • Collector, emitter, and gate?
  • Do you have any guide test that we can perform to guarantee that the IGBT is okay?
Thanks in advance.
Guru_Prasad
250 replies posted 100 solutions authored 25 likes received
Dear @Iancalazans
Thanks for posting your question in the Infineon community.
My answers to your questions are given below
• Do you have any value of resistance that is acceptable for the following parts:
o Collector, emitter, and gate?
Ans)Please let me what values are observing while you are testing
1)Gate to the emitter
2)collector to emitter
Ans) In the datasheet the SOA values are given please look into it ..
I hope you are also check in my cases also. Please continue the discussion in my cases only.
Thank you
Guru
Guru_Prasad
Dear @Iancalazans
Thank you
Guru
Iancalazans
Hi Guru,
        The IGBT's that we have installed have high values of resistance, do you know any laboratory that we can send the IGBT's to test and analyze?
Guru_Prasad
Hello @Iancalazans
Could you share the test results with us? After the results analysis, we can decide.
Thank you
Guru
Iancalazans
Hi Guru,
                  Attached 2 reports of our PV Inverters repaired with the
Guru_Prasad
Hello @Iancalazans
All measurements are fine except yellow marked values.
what this is limit for R_Cond and R_blog? How is this measured?
Thank you
Guru
