User22731
08:20 AM
- Email to a Friend
I am getting an error after powering up the LB of my HybridKit Sense. I can also see the the 5V to the LEM sensor is not generated by the LB.
Don't really know where to look to find a solution here. Thanks for you replies.
BR,
Laurent
P.S. The console output aftr power up
>>> Booting hybrid kit
>>> Initializing timer (1ms timer)
>>> - Timer: GTM, ATOM2.0
>>> - Frequency: 1000.000000 Hz
>>> .........[OK]
>>> Initializing QSPI0
>>> - CLK=P20.11, MTSR=P20.14, MRST=P22.6
>>> - DMA TX=1, DMA RX=0
>>> .........[OK]
>>> Initializing QSPI0 channel CS0 (logic board EEPROM)
>>> - 3000000 baud
>>> .........[OK]
>>> Initializing QSPI0 channel CS1 (driver board 0 EEPROM)
>>> - 200000 baud
>>> .........[OK]
>>> Class: HkLogicBoardv4r2
>>> Reading logic board information ...
>>> Board: Hybrid kit logic board
>>> Board version: 4.2r0
>>> Board number: 353
>>> Reading logic board parameters ...
>>> Parameter file version: 1.12
>>> Initializing QSPI2 [OK]
>>> Initializing SMU [OK]
>>> Initializing SCU NMI pin [OK]
>>> Initializing QSPI2 channel CS0 (TLF35584)
[OK]
>>> Initializing TLF35584 [OK]
>>> Initializing IO 0 (digital out 0) [OK]
>>> Initializing IO 1 (digital out 1) [OK]
>>> Initializing IO 2 (digital out 2) [OK]
>>> Initializing IO 3 (digital out 3) [OK]
>>> Initializing IO 0 (digital in 0) [OK]
>>> Initializing IO 1 (digital in 1) [OK]
>>> Initializing IO 2 (digital in 2) [OK]
>>> Initializing IO 3 (digital in 3) [OK]
>>> Reading driver board 0 information ...
>>> Board: Hybrid kit HPDrive board with EiceSense Driver
>>> Board version: 1.4r0
>>> Board number: 353
>>> Reading driver board parameters ...
>>> Parameter file version: 1.5
>>> Normal mode entered
>>> Reading control parameters ...
>>> Parameter file version: 1.0
>>> Type 'help' to get the list of avaiable commands
>>> Type 'help' to get details about the command
Shell>
System [0x700233cc: LogicBoard] Error TLF35584 NMI
BR,
Laurent
>>> Booting hybrid kit
>>> .........[OK]
>>> Initializing QSPI0
>>> .........[OK]
>>> - 3000000 baud
>>> .........[OK]
>>> - 200000 baud
>>> .........[OK]
>>> Board number: 353
[OK]
>>> Board number: 353
>>> Normal mode entered
>>> Type 'help
Shell>
10:00 PM
- Email to a Friend
Hello @User22731
Thanks for posting your question in the Infineon community
The current sense will work while the load current (AC current) flows into the load (motor/Inductive load).
May I know your experimental set up details and the SW current reference values?
Guru
10:00 PM
- Email to a Friend
Hello @User22731
Guru
