We are having trouble interpreting the Iposim simulation of this (FF2MR12W3M1H_B11) SIC half bridge module in a boost configuration. The results refer to "diode" switching losses being "not calculated". Is the simulation assuming we are leaving the top switch off and using the diode? If so - why doesn't it calculate the diode switching losses? If not, Where are the top transistor losses? And there are some anomalous results. We find if we reduce the boost inductance - the transistor total dissipation goes down but its junction temperature goes up.
Here is our model:
Any advice appreciated...
Richard.
Hello @Rchapman
The SiC half module can use for the Boost application. it can be replaced with a boost switch and boost diode. unfortunately, the IPOSIM can validate only switch losses and its anti-parallel diode losses, not boost converter diode losses. so in your application, the switch anti-parallel diode is not conducting that is why losses are not calculated. Since the IPOSIM can do only switch calculations, not for diode hence upper switch losses are not shown.
Guru
Hello @Rchapman
Thanks for posting your question in the Infineon community.
we are working on this query we will get back to you
Thank you
Guru
Hello @Rchapman
Guru
