How can i adjust the output voltage of the EVAL-PFC5KIKWWR5SYS ?
fallma
I wish to lower the output voltage of the EVAL-PFC5KIKWWR5SYS from 400V to 300V. Does someone know how to do that ?
thanks
Anil_Y
10 likes received 25 solutions authored 10 solutions authored
Dear @fallma ,
Good day!!
Change the voltage across the VSENSE pin in the UCC28070DW PFC controller by changing the R7 resistance value according to the voltage divider rule. According to this voltage change, PWM signals will be generated.
Note: This is not recommended.
We need to change the components to change the output voltage.
Thanks for understanding.
Anil Kumar.
Anil_Y
Dear @fallma ,
Good day!!
As this is an interleaved boost PFC board operating in CCM mode for the input of 230V rms (325 V peak) we can get above this voltage only.
Anil Kumar.
fallma
Thank you for your answer.
My input voltage will be 180V. How low can I have as output voltage and how do I adjust it to that level ?
Thank you
Anil_Y
Dear @fallma ,
Good day!!
Anil Kumar.
