Hi, in multi-phase systems, what problems will be caused by simultaneous multi-phase switching operation?
Taking three-phase two-level inverter as an example, generally, only one phase leg will be switched to the upper/lower DC rail. But what problems will be caused if two- or three-phase legs are switched to the upper/lower DC rail at the same time?
Stronger EMI?
For example, simultaneous three-phase switching operations will occur at the boundaries of the carrier periods when using single-edge modulation as shown in the attached Figure.
Hi @Desheng_Zhang,
Conventional PWM techniques (like SVPWM) shall switch in the below switching pattern.
If you observe the above PWM pattern, transition of the switches shall happen one leg at a time.
Practically, we won't turn off all three leg switches simultaneously. Please specify the application for which you require the forced PWM switching pattern.
Switches will experience significant stresses as a result of the high di/dt and dv/dt that will result from hard switching, as you described.
The traditional hard switching inverter has a number of drawbacks, including high switching power losses, high device stresses, poor performance, low efficiency, and EMI production from high di/dt and high dv/dt due to fast transitions.
Please go through the attached reference.
Thanks for your attention. Switching two or more phases at the same time may be problematic in the sense of noise generation. I have met a problem that motor vibration sensors cannot work properly when there are simultaneous multi-phase switching operations generated, perhaps due to stronger EMI.
In addition, I think simultaneous multi-phase switching operations may have more disadvantages, such as larger di/dt, larger voltage spikes, bad common-mode behaviors, and perhaps challenges to the tolerable voltage of the power device.
However, I was not able to find the relevant literature in IEEE Xplore. Maybe this issue should be given enough attention in industry and I am very much looking forward to your reply! Thanks!
Hi @Desheng_Zhang,
Thanks!!
