Janmay
First like received 10 questions asked 10 replies posted
I am looking for suitable gate driver ICs, should be in stock, for FF600R17ME4P, FF600R17ME4P | 1700 V, 600 A dual IGBT module - Infineon Technologies
Peak current requirement is 4 A.
Please suggest, thank you.
Janamejaya
AZIZ_HASSAN
50 likes received 5 likes given 250 sign-ins
Please find the link below which will suffice your requirement of 6A source current with DESAT protection.
https://www.infineon.com/dgdl/Infineon-1ED332xMC12N-DataSheet-v01_01-EN.pdf?fileId=8ac78c8c7ddc01d70...
Part no.- 1ED3322MC12N
If you wish to explore more, please go through the link attached below.
https://www.infineon.com/cms/en/product/power/gate-driver-ics/eicedriver-enhanced/
BR,
AZIZ
AZIZ_HASSAN
Thanks for posting at Infineon community.
To help you accurately, can you please let me know your working and maximum DC bus voltage.
BR,
AZIZ
Working voltage 800 V, maximum voltage 1000 V.
AZIZ_HASSAN
There are many portfolios available for this kind of switch.
I would like to introduce one with you i.e. 1EDC30I12MHXUMA1.
However, if you have any additional or specific feature as per you requirement, I request you to go to the page link below and select one.
https://www.infineon.com/cms/en/product/power/gate-driver-ics/high-side-drivers/
BR,
AZIZ
Thanks, but is there a Gate driver IC for FF600R17ME4P with Desat protection?
AZIZ_HASSAN
I found a suitable gate driver IC which is very strong and have many protections like DESAT. The part number is -  1ED020I12-F2
Below is the link of the same.
https://www.infineon.com/dgdl/Infineon-1ED020I12-F2-DataSheet-v02_01-EN.pdf?fileId=db3a304330f686060...
BR,
AZIZ
Any Gate driver that can source 6 A and also has DESAT?. Please let me know. Thanks.
Janmay
AZIZ_HASSAN
BR,
AZIZ
Thank you very much, I greatly appreciate your help. Thanks.
Hello @AZIZ_HASSAN ,
One last question, is 1ED3322MC12N Automotive grade ?, AECQ qualified?.
AZIZ_HASSAN
This GD IC is industrial grade.
BR,
AZIZ
Thank you.
Thank you, the website 1ED3322MC12N - Infineon Technologies states Fast EV charging as one of the applications. So I assumed the IC might be automotive grade.
Is there an automotive/AECQ qualified part with similar features?. Thanks.
AZIZ_HASSAN
Since, the ticket is closed, I request you to open a new ticket for automotive grade GD IC.
Thx.
BR,
AZIZ
