- Email to a Friend
Where can I find CAD and PLECS model for the FS380R12A6T4BBPSA1?
- Email to a Friend
Hello @iamprt
The link which has been given in the previous post will work but you need to login myinfineon to see stp file.
anyway I have given the procedure below please follow
Step-1 Please click the below link
Step-2 Please login my Infineon at top right corner please see below-mentioned image for your reference
Step-3 In boards/PCB design data you can see stp file. please see in below mentioned image
Guru_Prasad
- Email to a Friend
Hello @iamprt
Thanks for posting your question in Infineon.
The stp file is having the 3D models so it will help for your CAD data. Please use this link for stp file. you can
download the stp file under boards/PCB design data. while you are downloading please log in to my Infineon.
At the moment we don't have a PLECS model. let me know your requirements here we will provide the right
path for alternatives for PLECES model.
Guru
- Email to a Friend
@Guru_Prasad can you please specify where on the link is stp file?
- Email to a Friend
Hello @iamprt
Guru_Prasad
